AC to DC 3.3V/5V/9V/12V/15V/24V 3w Step Down mini Power Supply Converter Module switch power module HLK-3M05BL/3M12BL/3M15BL/3M24BL
Visitor3597
Price$1.68
| Altitude | ≤2000 m |
| Input low start | ≤300mS |
| No-load rated output voltage | 5.0±0.1Vdc |
| Rated output current | 600mA |
| Ripple/Noise | ≤50mV |
