AC to DC 15W 5V/9V/12V/15V/24V step down mini power switch supply power converter module HLK-15M05BL/15M12BL/15M15BL/15M24BL
Visitor2204
Price$2.41
| Altitude | ≤2000 m |
| The maximum input CURRENT | ≤0.3A |
| Input inrush current | ≤34A |
| Input low start | ≤50mS |
Output Features(5V/3000mA)
| No-load rated output voltage | 5.0±0.2Vdc |
| Short term maximum output current | ≥3700mA |
| Rated output current | 3000mA |
| Load regulation rate | ±0.3% |
| Output over-current protection Output maximum load | 110-130% A |
| Ripple/Noise | ≤100mVp-p(Typ:50) |
Output Features(9V/1660mA)
| No-load rated output voltage | 9.0±0.2Vdc |
| Full-load rated output voltage | 9.0±0.2Vdc |
| Short term maximum output current | ≥1990mA |
| Rated output current | 1660mA |
Output Features(12V/1250mA)
| No-load rated output voltage | 12.0±0.3Vdc |
| Full-load rated output voltage | 12.0±0.3Vdc |
| Short term maximum output current | ≥1500mA |
| Rated output current | 1250mA |
| Voltage regulation rate | ±0.3% |
Output Features(15V/1000mA)
| No-load rated output voltage | 15.0±0.2Vdc |
| Full-load rated output voltage | 15.0±0.3Vdc |
| Short term maximum output current | ≥1260mA |
| Voltage regulation rate | ±0.5% |
Output Features(24V/625mA)
| No-load rated output voltage | 24.0±0.5Vdc |
| Full-load rated output voltage | 24.0±0.3Vdc |
| Short term maximum output current | ≥790mA |
| Rated output current | 625mA |
| Recommended Component | Function | Recommended Parameters |
| F1/fuse | When the module is abnormal, protect the circuit from damage | 1A/250Vac, slow fuse |
| MOV1/Varistor | The cumulative surge is to protect the module from damage | 10D561K |
| C1/Safety capacitance | Filtering/safety protection/EMC certification | 0.1uF/275VAC |
| L1/Common-mode inductance | EMI filtering | Sensible value 10-30mH(testing requirements 1KHZ/0.3V current:100-500mA) |
