  4. AC DC 15W
  5. Ultra small size AC-DC isolation switch power module 15M12T/15M05T/15M15T 220V to 5V9V15V24V voltage regulator module
    $2.88
15WT Series Mode list 拷贝
Product Introduction
15W is a small-sized, high-efficiency, and ultra small series module power supply designed by Shenzhen Hi-link Electronics for customers. It adopts the most advanced gallium nitride chip solution and has the advantages of global input voltage range, low temperature rise, low power consumption, high efficiency, high reliability, and high safety isolation. It is widely used in industries such as smart homes, automation control, communication equipment, and instrumentation.
  • Ultra thin, compact, and the smallest volume in the industry
  • Global universal input voltage (100~240Vac)
  • Low power consumption, green environmental protection, no-load loss<0.1W
  • Low ripple, low noise
  • Good output short circuit and overcurrent protection with self recovery capability
  • Input/output isolation withstand voltage 3000Vac
  • 100% full load aging and testing
  • High reliability, long-life design, continuous working time greater than 100000 hours
  • Meet UL and CE safety requirements;
  • Using high-quality environmentally friendly waterproof thermal conductive adhesive for sealing, moisture-proof and vibration proof, meeting the IP65 standard for waterproof and dustproof
  • Economic solutions with high cost-effectiveness
  • Can work without external circuitry
  • 1-year quality warranty period
Working Temerature-25—+60 ℃
Storage temperature-40—+80 ℃
Relative humidity5—95 %
Altitude≤2000 m
Rated input voltage100-240Vac
The maximum input CURRENT≤0.4A
Input inrush current ≤40A
Input low start≤50mS
External fuse recommended1A/250Vac,  Slow blow
Output Features(5V/3000mA)
No-load rated output voltage5.0±0.3Vdc
Full-load rated output voltage5.0±0.3Vdc
Short term maximum output current≥3000mA
Rated output current4000mA
Voltage regulation rate±0.2%
Load regulation  rate±0.5%
Output over-current protection Output maximum load130-180% A
Ripple/Noise≤100mVp-p(Typ:50)
Output Features(12V/1250mA)
No-load rated output voltage12.0±0.3Vdc
Full-load rated output voltage12.0±0.4Vdc
Short term maximum output current≥2000mA
Rated output current1250mA
Output Features(15V/1000mA)
No-load rated output voltage15.0±0.3Vdc
Full-load rated output voltage15.0±0.4Vdc
Rated output current1000mA
Output Features(24V/625mA)
No-load rated output voltage24.0±0.3Vdc
Full-load rated output voltage24.0±0.4Vdc
Short term maximum output current≥800mA
Rated output current625mA
Output over-current protection Output maximum load110-180% A
15w-t
Input Parameter Recommendation
Recommended ComponentFunction
Recommended Parameters
F1/fuseWhen the module is abnormal, protect the circuit from damage2A/250Vac, slow fuse
HLK-20EMI
EMC attenuator
HLK-20EMI 拷贝
Fuses are the basic protection circuit and must be connected
Output Parameter Recommendation
Recommended ComponentFunctionRecommended Parameters
C1/filter capacitorAfter filtering and adding this capacitor, users can adjust the output ripple voltageAluminum electrolytic capacitor, capacity 100-220uF, resistant to
Pressure drop greater than 75%
Meet UL/CE requirements
