  4. AC DC 20W
  5. AC to DC 20W HLK-20M05C/20M12C/20M24C Step Down mini Power Supply Converter Module Insert EMC Electric Circuit
    $3.15
product list-3
Working Temerature-25—+60 ℃
Storage temperature-40—+80 ℃
Relative humidity5—95 %
Altitude≤2000 m
Rated input voltage100-240Vac
The maximum input CURRENT≤0.4A
Input low start≤50mS
External fuse recommended2A/250Vac, Slow blow
Output Features(5V/3600mA)
No-load rated output voltage5±0.1Vdc
Full-load rated output voltage5±0.2Vdc
Short term maximum output current≥4200mA
Rated output current4000mA
Voltage regulation rate±0.2%
Load regulation  rate±0.5%
Output ripple and noise
≤100
Rated input voltage, output at full load. Using a 20MHz bandwidth oscilloscope,
Test the load end with 10uF and 0.1uF capacitors.
Output Features(9V/2200mA)
No-load rated output voltage9±0.1Vdc
Full-load rated output voltage9±0.2Vdc
Short term maximum output current≥2300mA
Rated output current2200mA
≤100
Output Features(12V/1660mA)
No-load rated output voltage12±0.1Vdc
Full-load rated output voltage12±0.2Vdc
Short term maximum output current≥1700mA
Rated output current1660mA
≤100
Output Features(15V/1330mA)
No-load rated output voltage15±0.1Vdc
Full-load rated output voltage15±0.2Vdc
Short term maximum output current≥1430mA
Rated output current1330mA
≤100
Output Features(24V/830mA)
No-load rated output voltage24±0.1Vdc
Full-load rated output voltage24±0.2Vdc
Short term maximum output current≥900mA
Rated output current830mA
≤100
Recommended ComponentFunction
Recommended Parameters
F1/fuseWhen the module is abnormal, protect the circuit from damage1A/250Vac, slow fuse
MOV1/VaristorThe cumulative surge is to protect the module from damage10D561K
C1/Safety capacitanceFiltering/safety protection/EMC certification0.1uF/275VAC
L1/Common-mode inductanceEMI filteringSensible value 10-30mH(testing requirements 1KHZ/0.3V current:100-500mA)
