  4. AC DC 15W
  5. AC to DC 15W 5V/9V/12V/15V/24V step down mini power switch supply power converter module HLK-15M05B/15M12B/15M15B/15M24B
    $2.54
15W-B Series Mode list
Working Temerature-25—+60 ℃
Storage temperature-40—+80 ℃
Relative humidity5—95 %
Altitude≤2000 m
Rated input voltage100-240Vac
The maximum input CURRENT≤0.3A
Input inrush current ≤34A
Input low start≤50mS
Output Features(5V/3000mA)
No-load rated output voltage5.0±0.2Vdc
Short term maximum output current≥3700mA
Rated output current3000mA
Voltage regulation rate±0.2%
Load regulation  rate±0.3%
Output over-current protection Output maximum load110-130% A
Ripple/Noise≤100mVp-p(Typ:50)
Output Features(9V/1660mA)
No-load rated output voltage9.0±0.2Vdc
Full-load rated output voltage9.0±0.2Vdc
Short term maximum output current≥1990mA
Rated output current1660mA
Load regulation  rate±0.5%
Output Features(12V/1250mA)
No-load rated output voltage12.0±0.3Vdc
Full-load rated output voltage12.0±0.3Vdc
Short term maximum output current≥1500mA
Rated output current1250mA
Voltage regulation rate±0.3%
Output Features(15V/1000mA)
No-load rated output voltage15.0±0.2Vdc
Full-load rated output voltage15.0±0.3Vdc
Short term maximum output current≥1260mA
Rated output current1000mA
Voltage regulation rate±0.5%
Output Features(24V/625mA)
No-load rated output voltage24.0±0.5Vdc
Full-load rated output voltage24.0±0.3Vdc
Short term maximum output current≥790mA
Rated output current625mA
Recommended ComponentFunction
Recommended Parameters
F1/fuseWhen the module is abnormal, protect the circuit from damage1A/250Vac, slow fuse
MOV1/VaristorThe cumulative surge is to protect the module from damage10D561K
C1/Safety capacitanceFiltering/safety protection/EMC certification0.1uF/275VAC
L1/Common-mode inductanceEMI filteringSensible value 10-30mH(testing requirements 1KHZ/0.3V current:100-500mA)
