85~305Vac Input AC/DC 3W 5V/9V/12V/15V/24V Step Down Mini Power Supply Converter Switch Power Module HLK-3LD05/3LD12/3LD24
Visitor7760
Price$2.12
Global universal input voltage(85-305Vac)
| Altitude | ≤2000 m |
| Rated input voltage | 100-277Vac |
| Input vlotage range | 85-305VAC/100-430VDC |
| Input frequency | 47-63Hz |
| Input low start | ≤200mS |
Output Features 5V(5V/600mA)
| No-load rated output voltage | 5.0±0.1Vdc |
| Short term maximum output current | ≥700mA |
| Rated output current | 600mA |
| Ripple/Noise | ≤300mV |
Output Features 9V(9V/600mA)
| No-load rated output voltage | 9.0±0.1Vdc |
| Full-load rated output voltage | 9.0±0.2Vdc |
| Short term maximum output current | ≥430mA |
| Rated output current | 330mA |
Output Features 12V(12V/250mA)
| No-load rated output voltage | 12.0±0.1Vdc |
| Full-load rated output voltage | 12.0±0.2Vdc |
| Short term maximum output current | ≥350mA |
| Rated output current | 250mA |
Output Features 15V(15V/200mA)
| No-load rated output voltage | 15.0±0.1Vdc |
| Full-load rated output voltage | 15.0±0.2Vdc |
| Short term maximum output current | ≥300mA |
| Rated output current | 200mA |
Output Features 24V(24V/125mA)
| No-load rated output voltage | 24.0±0.1Vdc |
| Full-load rated output voltage | 24.0±0.2Vdc |
| Short term maximum output current | ≥220mA |
| Rated output current | 125mA |
