3LS03/3LS05/3LS09/3LS12/3LS15/3LS24 AC-DC 220v to 3.3/5/9/12/15/24V 3w Step Down Mini Power Supply Converter Module
Visitor11365
Price$1.17
| Altitude | ≤2000 m |
| Input low start | ≤300mS |
Output Features(3.3V/600mA)
| No-load rated output voltage | 3.3±0.1Vdc |
| Full-load rated output voltage | 3.3±0.1Vdc |
| Short term maximum output current | ≥990mA |
| Rated output current | 600mA |
| Voltage regulation rate | ±0.1% |
Output Features(5V/600mA)
| No-load rated output voltage | 5±0.1Vdc |
| Full-load rated output voltage | 5±0.1Vdc |
| Short term maximum output current | ≥890mA |
Output Features(12V/250mA)
| No-load rated output voltage | 12±0.4Vdc |
| Full-load rated output voltage | 12±0.4Vdc |
| Short term maximum output current | ≥350mA |
| Rated output current | 420mA |
| Voltage regulation rate | ±0.3% |
Output Features(24V/208mA)
| No-load rated output voltage | 24±0.2Vdc |
| Full-load rated output voltage | 24±0.2Vdc |
| Short term maximum output current | ≥200mA |
| Rated output current | 125mA |
| Voltage regulation rate | ±0.5% |
Input parts
| Recommand component | Function | Introduce value |
| F1/Fuse | When the module is abnormal, protect the circuit from damage | 1A/250Vac or 10Ω wire wound resistor, slow fuse |
| MOV1/Varistor | The cumulative surge is to protect the module from damage | 10D561K |
| C1/Safety capacitance | (Filtering/safety protection/EMC certification | 0.1uF/275VAC |
| L1/Common-mode inductance | EMI filtering | Sensible value 10-30mH(testing requirements 1KHZ/0.3V current:100-500mA) |
Remarks:
Fuses and varistors are the basic protection circuits (must be connected).
If certification is required, safety capacitors and common mode inductors cannot be omitted.
Output parts
| C2/filtering capacitor | After filtering and adding this capacitor, users can adjust the output ripple voltage | Aluminum electrolytic capacitor, with a capacitance value of 100-220uF and a withstand voltage rating reduction greater than 75% |
| RL/Load | Load |
