  4. DC DC 1W
  5. E0505S-1WR3 E0509/E0512/E0515/E0524S-1WR3 DC-DC isolated non stabilized dual output power converter module with short-circuit protection
    $0.98
E_S Series Mode list 拷贝
Product Features:
  • 5Pin SIP international standard pin
  • Isolation voltage: 3000VDC
  • High conversion efficiency, up to 89%
  • Low ripple coefficient and low noise
  • Working environment temperature: -40 ℃~+85 ℃
  • MTBF ≥ 3.5 million hours (3500000 Hrs)
  • Output short circuit protection: sustainable short circuit protection, automatic recovery
  • Built in soft start technology
  • Special specification products can be designed according to customer needs
Input characteristic:
Item
Working ConditionsMin.Typ.Max.Unit
3.3VDC input series--370/3--/15
5VDC input series--235/3--/15
Input voltage range12VDC input series--99/3--/15Vdc
15VDC input series--99/3--/15
24VDC input series--51/3--/15
Reflected ripple current
--15--
Impulse Voltage
3.3VDC input series-0.7--5Vdc
5VDC input series-0.7--9
12VDC input series-0.7--18
15VDC input series-0.7--21
24VDC input series-0.7--30
Input fliter typle
Capacitive filtering
Hot plug
Output characteristic:
ItemWorking and testing conditionMin.Typ.Max.Unit
----±15.0%
Linear adjustment rateInput voltage variation ±1%3.3V output
----±1.5%
others----±1.2%
Load adjustment rate10%~100% load3.3VDC output--10--%
5VDC output--8
9VDC output--8--%
12VDC output--7--%
15VDC output--6--%
24VDC output--6--%
Ripple & NoisePure resistive load, 20HMz bandwidth, peak-to-peak--45100mVp-p
Temperature Drift CoefficientFull load----±0.03%/℃
General characteristic:
Item
Working conditionMin.Typ.Max.Unit
Insulation voltageInput output, test time of 1 minute, leakage current less than 1mA3000----VDC
Insulation resistance Input output, insulation voltage 500VDC 1000-M Ω1000----MΩ
Isolation capacitorInput output, 100KHz/0.1V --40-- pF--20--pF
Working temperature Use reference temperature derating curve chart-40--+85
Storage temperature
-40--+125
Temperature rise of the casing during operation
--25--
Storage humidityNo condensation5--95%RH
Pin resistance to welding temperatureWelding point distance from the shell 1.5mm, 10 seconds----+300℃
Switching frequency Full load, nominal voltage input--100--KHz
Shock
10-55Hz, 10G, 30 Min. along X, Y and Z
Shell material
Black flame retardant and heat-resistant plastic (UL94V-0)
Minimum time between failuresMIL-HDBK-217F@25℃3.5X10 6----Hrs
