  4. DC DC K78XX Series
  5. DC DC Power Supply Module K7805-2000R3 K7802/K7803/K7809/K7812/K7815-2000R3/R3L non isolated power supply
    $1.42
K78xx_2000R3-1
  • Wide voltage input, non isolated stable single output
  • Efficiency up to 96%
  • Working environment temperature: -40 ° C~+85 ° C
  • No load input current as low as 0.1mA
  • Output short circuit protection
  • Pin compatible with LM78xx series
  • Small SIP package, plastic shell
No load input currrent
Nominal input voltage, 2.5V output
-0.20.5mA
Other output
0.12
Reverse input
prohibit
Input fliter type
capacity fliter
Hot-swapping
Not support
ItemWorking and testing conditionsMinTyp.Max
voltage accuracyFull load, input voltage range2.5V/3.3V output--±2±4
Others--±2±3
Line Regulation
Full load, input voltage range--±0.4±0.8
Load RegulationNominal input voltage, 10%~100% load--±0.5±1.5
Ripple&Noise20MHz bandwidth, nominal input voltage, 100% load--3075
Temperature drift coefficientWorking temperature -40℃-+85℃----±0.03
Transient response deviation
Nominal input voltage, 25% -50% -25%, 50% -75% -50% load step change2.5V output--±80±150
Others--±50±150
During transient recovery
--0.21
Short Circuit ProtectionNominal input voltage
sustainable, automatic recovery
