2000W AC/DC switching power supply 110V output high power DC adjustable constant voltage and constant current HLK-2000QYL110
Visitor1180
Price$80.50
HLK-QYL-2000W is a 2KW single output chassis type AC to DC/DC to DC power supply. The input voltage range of the entire series is 180-264VAC/250-370VDC, and it can provide DC output that can meet most industrial needs. Each model can be cooled by an internal speed controlled fan, with a working temperature of up to 60 ℃. Built in multiple functions such as adjustable output voltage and current, remote on/off control, auxiliary power supply, etc. provide various design flexibility
HLK-2000QYL12 | 277*155*70mm (L*W*H) | 2000W | 12V | 0~166.6A | |
HLK-2000QYL24 | 24V | 0~83.3A | |||
HLK-2000QYL36 | 36V | 0~55.5A | |||
HLK-2000QYL48 | 48V | 0~41.6A | |||
HLK-2000QYL72 | 72V | 0~27.7A | |||
HLK-2000QYL96 | 96V | 0~20.8A | |||
HLK-2000QYL110 | 110V | 0~18.1A | |||
HLK-2000QYL150 | 150V | 0~13.3A | |||
HLK-2000QYL220 | 220V | 0~9A |
Laser related machines
UV curing equipment
Charging equipment
Aging equipment
Altitude | ≤2000 | m | |
AC current | < 20A | A | |
Project name | HLK-2000QYL12 | HLK-2000QYL24 | HLK-2000QYL36 | HLK-2000QYL48 | HLK-2000QYL72 | Unit |
Rated current | 166.6A | 83.3A | 55.5A | 41.6A | 27.7A | A |
Current range | 0~166.6A | 0~83.3A | 0~55.5A | 0~41.6A | 0~27.7A | A |
Project name | HLK-2000QYL96 | HLK-2000QYL110 | HLK-2000QYL150 | HLK-2000QYL220 | Unit | |
Rated current | 20.8A | 18.1A | 13.3A | 9A | A | |
Current range | 0~20.8A | 0~18.1A | 0~13.3A | 0~9A | A | |
Project name | Unit | |
