  4. AC DC 1000W
  5. 1000W AC/DC switching power supply 110V output high power DC adjustable constant voltage and constant current HLK-1000QYL110
    $46.00
HLK-1000QYL series is a 1KW single output chassis type AC to DC/DC to DC power supply. The input voltage range of the entire series is 180-264VAC/250-370VDC, and it can provide DC output that can meet most industrial needs. Each model can be cooled by an internal speed controlled fan, with a working temperature of up to 60 ℃. Built in multiple functions such as adjustable output voltage and current, remote on/off control, auxiliary power supply, etc. provide various design flexibility
Dimension(mm)
Output power (W)
Output voltage (V)
Output current range (A)
HLK-1000WQYL12
  237*130*35
1000W
0~83.3A
HLK-1000WQYL24
0~41.7A
HLK-1000WQYL36
0~27.8A
HLK-1000WQYL48
0~20.8A
HLK-1000WQYL72
0~13.9A
HLK-1000WQYL96
0~10.4A
HLK-1000WQYL110
0~9.1A
HLK-1000WQYL150
0~6.7A
HLK-1000WQYL220
0~4.5A
< 11A
HLK-1000QYL12
HLK-1000QYL24
HLK-1000QYL36
HLK-1000QYL48
HLK-1000QYL48
83.3A
41.7A
27.8A
20.8A
13.9A
0~83.3A
0~41.7A
0~27.8A
0~20.8A
0~13.9A
      HLK-1000QYL96
HLK-1000QYL110
HLK-1000QYL150
HLK-1000QYL220
10.4A
9.1A
6.7A
4.5A
0~10.4A
0~9.1A
0~6.7A
0~4.5A
1. All parameters, unless otherwise specified, are measured at 230VAC voltage input, rated load, and
25 ℃ conditions.
2. Ripple and noise voltage were measured on a 20MHz bandwidth oscilloscope with 0.1 μ and 47 μ
capacitors added to the end of a 12 inch twisted pair cable, and measured at a 20MHz bandwidth.
4. When the input voltage is low, the output needs to be reduced. Please refer to the static characteristic
curve diagram for details.
5. The start-up time is measured when the refrigeration machine is started, and frequent power on and
off may increase the start-up time.
