1000W AC/DC switching power supply high power converter 12V output with DC adjustable constant voltage and constant current HLK-1000QYL12
Visitor998
Price$46.00
HLK-1000QYL series is a 1KW single output chassis type AC to DC/DC to DC power supply. The input voltage range of the entire series is 180-264VAC/250-370VDC, and it can provide DC output that can meet most industrial needs. Each model can be cooled by an internal speed controlled fan, with a working temperature of up to 60 ℃. Built in multiple functions such as adjustable output voltage and current, remote on/off control, auxiliary power supply, etc. provide various design flexibility
HLK-1000QYL12 | 237*130*35 | 800W | 12V | 0~66.7A | |
HLK-1000QYL24 | 1000W | 24V | 0~41.7A | ||
HLK-1000QYL36 | 36V | 0~27.8A | |||
HLK-1000QYL48 | 48V | 0~20.8A | |||
HLK-1000QYL72 | 72V | 0~13.9A | |||
HLK-1000QYL96 | 96V | 0~10.4A | |||
HLK-1000QYL110 | 110V | 0~9.1A | |||
HLK-1000QYL150 | 150V | 0~6.7A | |||
HLK-1000QYL220 | 220V | 0~4.5A |
Laser related machines
UV curing equipment
Charging equipment
Aging equipment
Altitude | ≤2000 | m | |
AC current | < 11A | A | |
Project name | HLK-1000QYL12 | HLK-1000QYL24 | HLK-1000QYL36 | HLK-1000QYL48 | HLK-1000QYL72 | Unit |
Rated current | 66.7A | 41.7A | 27.8A | 20.8A | 13.9A | A |
Current range | 0~66.7A | 0~41.7A | 0~27.8A | 0~20.8A | 0~13.9A | A |
Project name | HLK-1000QYL96 | HLK-1000QYL110 | HLK-1000QYL150 | HLK-1000QYL220 | Unit | |
Rated current | 10.4A | 9.1A | 6.7A | 4.5A | A | |
Current range | 0~10.4A | 0~9.1A | 0~6.7A | 0~4.5A | A | |
Project name | Unit | |
