  4. AC DC 20W
  5. AC to DC 20W 5V/9V/12V/15V/24V step down mini power switch supply power converter module HLK-20M05B/20M12B/20M15B/20M24B
    $3.10
20W-B product list-3 拷贝
Working Temerature-25—+60 ℃
Storage temperature-40—+80 ℃
Relative humidity5—95 %
Altitude≤2000 m
Rated input voltage100-240Vac
The maximum input CURRENT≤0.4A
Input frequency47-63Hz
Input low start≤50mS
External fuse recommended2A/250Vac, Slow blow
Output Features(5V/4000mA)
No-load rated output voltage5.0±0.2Vdc
Short term maximum output current≥4200mA
Rated output current4000mA
Voltage regulation rate±0.2%
Load regulation  rate±0.5%
Output over-current protection Output maximum load110-150% A
Output Features(9V/2200mA)
No-load rated output voltage9.0±0.2Vdc
Full-load rated output voltage9.0±0.2Vdc
Short term maximum output current≥2400mA
Rated output current2200mA
Output Features(12V/1660mA)
No-load rated output voltage12.0±0.2Vdc
Full-load rated output voltage12.0±0.2Vdc
Short term maximum output current≥1860mA
Rated output current1660mA
Output Features(15V/1330mA)
No-load rated output voltage15.0±0.2Vdc
Full-load rated output voltage15.0±0.2Vdc
Short term maximum output current≥1530mA
Rated output current1330mA
Output Features(24V/830mA)
No-load rated output voltage24.0±0.2Vdc
Full-load rated output voltage24.0±0.2Vdc
Short term maximum output current≥1030mA
Rated output current830mA
20W-B DIMENSIONS 拷贝
