AC to DC 3.3V/5V/9V/12V/15V/24V 5w Step Down mini Power Supply Converter Module switch power module HLK-5M05BL/5M12BL/5M15BL/5M24BL
Visitor4678
Price$1.73
| Altitude | ≤2000 m |
| Input low start | ≤300mS |
| No-load rated output voltage | 5.0±0.1Vdc |
| Output over-current protection Output maximum load | 110-150% A |
| Ripple/Noise | ≤100mVp-p(Typ:50) |
