  4. AC DC 5W
  5. AC to DC 5W HLK-5M05C/5M12C/5M24C Step Down mini Power Supply Converter Module Switch Power Module Insert EMC Electric Circuit
    $2.24
5W-C Series Mode list
Working Temerature-25—+60 ℃
Storage temperature-40—+80 ℃
Relative humidity5—95 %
Altitude≤2000 m
Rated input voltage100-240Vac
Input low start≤200mS
Output Features(3.3V/1500mA)
No-load rated output voltage3.3±0.1Vdc
Full-load rated output voltage3.3±0.1Vdc
Short term maximum output current≥1900mA
Rated output current1500mA
Voltage regulation rate±0.1%
Load regulation  rate±0.5%
Output ripple and noise
≤100
Rated input voltage, output at full load. Using a 20MHz bandwidth oscilloscope,
Test the load end with 10uF and 0.1uF capacitors.
Output Features(5V/1000mA)
No-load rated output voltage5±0.1Vdc
Full-load rated output voltage5±0.1Vdc
Short term maximum output current≥1260mA
Rated output current1000mA
≤100
Output Features(12V/420mA)
No-load rated output voltage12±0.1Vdc
Full-load rated output voltage12±0.1Vdc
Short term maximum output current≥520mA
Rated output current420mA
≤100
Output Features(24V/208mA)
No-load rated output voltage24±0.1Vdc
Full-load rated output voltage24±0.1Vdc
Short term maximum output current≥260mA
Rated output current208mA
≤100
Recommended ComponentFunction
Recommended Parameters
F1/fuseWhen the module is abnormal, protect the circuit from damage1A/250Vac, slow fuse
MOV1/VaristorThe cumulative surge is to protect the module from damage10D561K
C1/Safety capacitanceFiltering/safety protection/EMC certification0.1uF/275VAC
L1/Common-mode inductanceEMI filteringSensible value 10-30mH(testing requirements 1KHZ/0.3V current:100-500mA)
