85~305Vac Input AC/DC 5W 5V/9V/12V/15V/24V Step Down Mini Power Supply Converter Switch Power Module HLK-5LD05/5LD12/5LD24
Visitor7871
Price$1.69
Global universal input voltage(85-305Vac)
| Altitude | ≤2000 m |
| Rated input voltage | 100-277Vac |
| Input vlotage range | 85-305VAC/100-430VDC |
| Input frequency | 47-63Hz |
| Input low start | ≤200mS |
Output Features 5V(5V/1000mA)
| No-load rated output voltage | 5.0±0.1Vdc |
| Voltage regulation rate | ±0.1% |
| Ripple/Noise | ≤300mV |
Output Features 9V(9V/560mA)
| No-load rated output voltage | 9.0±0.1Vdc |
| Full-load rated output voltage | 9.0±0.2Vdc |
| Short term maximum output current | ≥840mA |
| Rated output current | 560mA |
Output Features 12V(12V/420mA)
| No-load rated output voltage | 12.0±0.1Vdc |
| Full-load rated output voltage | 12.0±0.2Vdc |
| Short term maximum output current | ≥675mA |
| Rated output current | 420mA |
Output Features 15V(15V/333mA)
| No-load rated output voltage | 15.0±0.1Vdc |
| Full-load rated output voltage | 15.0±0.2Vdc |
| Rated output current | 500mA |
Output Features 24V(24V/210mA)
| No-load rated output voltage | 24.0±0.1Vdc |
| Full-load rated output voltage | 24.0±0.2Vdc |
| Short term maximum output current | ≥310mA |
| Rated output current | 210mA |
