H0505S-1WR3/H0503S/H0512S/H0515S/H0524S-1WR3 DC to DC 5V to 3.3V/5V/9V/12V/15V/24V 1W power module/converter module single output
Visitor6655
Price$1.10
1. characteristic:stablized voltage input, isolated non stabilized voltage single output,1W
2. Isolation voltage 6000VDC
| Project name | Working condition | Min | Typ. | Max. | Unit |
| Insulation voltage | Input output, test time 1 minute, leakage current less than 1mA | 6000 | -- | -- | VDC |
| Insulation resistance | Input output, insulation voltage 500VDC | 1000 | -- | -- | MΩ |
| Isolation capacitor | Input output, 100KHz/0.1V | -- | 20 | -- | pF |
| Working enviroment temperature | -40 | -- | +85 | ℃ | |
| Storage temperture | -40 | -- | +125 | ℃ | |
| Relative humidity | No condensation | 5 | -- | 95 | %RH |
| Pin soldering temperature resistance | Welding point distance from shell 1.5mm, 10 seconds | -- | -- | +300 | ℃ |
| Switching frequency | Full load, nominal voltage input | -- | 250 | -- | KHz |
| Input current (full load/no load) | 3.3VDC Input Series | -- | 378/6 | --/12 | m'A |
| 5VDC Input Series | -- | 224/5 | --/10 | ||
| 12VDC Input Series | -- | 93/3 | --/5 | ||
| 15VDC Input Series | -- | 74/2 | --/4 | ||
| 24VDC Input Series | -- | 47/1 | --/2 | ||
| Impulse voltage | 3.3VDC Input Series | -0.7 | -- | 5 | VDC |
| 12VDC Input Series | -0.7 | -- | 18 | ||
| 15VDC Input Series | -0.7 | -- | 21 | ||
| Output Voltage Accuracy | See Error Envelope Curve | -- | -- | ±15.0 | % | |
| Linear adjustment rate | Input voltage variation ±1% | 3.3V output | -- | -- | ±1.5 | % |
| others | -- | -- | ±1.2 | % | ||
| Load adjustment rate | 10%~100% load | 3.3VDC Output | -- | 18 | -- | % |
| 5VDC Output | -- | 12 | -- | % | ||
| 9VDC Output | -- | 8 | -- | % | ||
| 12VDC Output | -- | 7 | -- | % | ||
| 15VDC Output | -- | 6 | -- | % | ||
| 24VDC Output | -- | 5 | -- | % | ||
| Output short circuit protection | Continuous short circuit protection, automatic recovery | -- | ||||
1. Routine application:
If it is required to further reduce the input and output ripple, a capacitive filter network can be connected at the input and output terminals, and the application circuit is shown in Figure 1.
However, attention should be paid to the selection of appropriate filtering capacitors. If the capacitor is too large, it is likely to cause startup problems. For each output, the recommended capacitive load value is shown in Table 1 under the condition of safe and reliable operation.
2.EMI typical application circuit
| Cin Capacitance | Filter capacitor | 4.7μA/50V |
| Cout Capacitance | Filter capacitor | Refer to usual application |
| Lin inductance | Filter inductance | Inductance: 4.7uH |
| Lout inductance | Cin Capacitance | Inductance: 4.7uH |
3. Output Load Requirements
