  4. DC DC K78XX Series
  5. K7803-1000R3/K7805-1000R3 DCDC non isolated power module with ultra wide voltage input ± 3.3V/5V regulated output
    $1.12
K78_-1000R3 Series Mode list 拷贝
1. Small SIP-3 package, international standard pin
2. No load input current as low as 0.1mA
3. Transfer efficiency up to 96%
4. Support negative output
5. Output short-circuit protection
No load input currrent
Positive output-0.11.0mA
Reverse input
prohibit
input fliter type
capacity fliter
ItemWorking and testing conditionsMinTyp.Max
voltage accuracyFull load, input voltage range3.3V output--±2±4
Others--±2±3
Line Regulation
--±0.2±0.4
Load Regulation10%-100% load3.3/5V output--±0.6--
others--±0.3--
Ripple&Noise
Pure resistive load, 20MHz bandwidth, peak to peak value, 20% -100% load
--2070
Temperature drift coefficientWorking temperature -40℃-+85℃----±0.03
Transient response deviation
Nominal input voltage, 25% -50% -25%, 50% -75% -50% load step change--50250
During transient recovery
--0.21
Long term short circuit, automatic recovery
①The testing method for ripple and noise adopts parallel line testing method
②When the load is below 10%, the maximum ripple and noise output of 3.3V/5V is 150mVp-p, and the maximum ripple and noise output of 9V/12V/15V is 2% Vo.
dimension 拷贝
