K7803M-1000R3 DCDC non isolated power module with ultra wide voltage input ± 3.3V regulated output
Visitor4031
Price$1.15
1. Small SIP-3 package, international standard pin
2. No load input current as low as 0.3mA
3. Transfer efficiency up to 96%
4. Support negative output
5. Output short-circuit protection
| No load input currrent | Positive output | - | 0.3 | 1.0 | mA |
| Negative output | - | 1 | 4 | ||
Reverse input | prohibit | ||||
| input fliter type | capacity fliter | ||||
| Item | Working and testing conditions | Min | Typ. | Max | |
| voltage accuracy | Full load, input voltage range | 3.3V output | -- | ±2 | ±4 |
| Others | -- | ±1.5 | ±3 | ||
Line Regulation | Full load, input voltage range | -- | ±0.2 | ±0.4 | |
| Load Regulation | 10%-100% load | positive output | -- | ±0.4 | ±0.6 |
| negative output | -- | ±0.4 | ±0.8 | ||
| Ripple&Noise | Pure resistive load, 20MHz bandwidth, peak to peak value, 20% -100% load | -- | 25 | 75 | |
| Temperature drift coefficient | Working temperature -40℃-+85℃ | -- | -- | ±0.03 | |
Transient response deviation | Nominal input voltage, 25% -50% -25%, 50% -75% -50% load step change | -- | ±60 | ±200 | |
During transient recovery | -- | -- | 1 | ||
| Short Circuit Protection | Long term short circuit, automatic recovery | ||||
①The testing method for ripple and noise adopts parallel line testing method
②When the load is below 20%, the maximum ripple and noise output of 3.3V/5V is 100mVp-p, and the maximum ripple and noise output of 9V/12V/15V is 2% Vo.
