  4. DC DC 2W
  5. DC-DC isolated power supply F0505XT-2WR3 F1205XT-2WR3 non regulated module with short circuit protection
    $0.76
FxxxxXT-2WR3-1
  • Features: Fixed voltage input, isolated non regulated output, power 2W
  • Isolation voltage 3000VDC
  • Working environment temperature: -40 ° C~+105 ° C
  • Efficiency up to 86%
  • Output short circuit protection: sustainable short circuit protection, automatic recovery
  • International standard pin method
  • Small SMD package
  • MTBF ≥ 3.5 million hours (3500000Hrs)
Input voltage range(fully loaded/unloaded)3.3VDC Input--740/8--mA
5VDC Input --476/8--
12VDC Input --196/8--
15VDC Input --161/8--
24VDC Input--98/8--
Reflected Ripple Current3.3VDC Input--30--mA
Others--15--
Impulse voltage  (Isec.max)3.3VDC Input-0.7--5VDC
5VDC Input -0.7--9
12VDC Input -0.7--18
15VDC Input -0.7--21
24VDC Input -0.7--30
Capacitive filtering
ItemWorking and testing conditionMin.Typ.Max.Unit
See the error envelope curve graph
Linear adjustment rateinput voltage change ±1%3.3V output--
--±1.5%
others----±1.2%
Load adjustment rate10%~100% rate
load
3.3VDC--
8
20%
5VDC--715%
9VDC--610%
12VDC--515%
15VDC--410%
24VDC--310%
Ripple & NoisePure resistive load, 20HMz bandwidth, peak-to-peak--50130mVp-p
Temperature drift coefficient
Pure resistive load, 20MHz broadband, peak to peak value----±0.02%/℃
Note: 1. Ripple and noise testing method - Twisted pair testing method.
