  4. 24G radar sensor module
  5. Hi-link 24G Human Presence Sensing LD2416 Radar Module AIP Ultra Small Size Smart Home Micro motion Static Detection Module
    $1.98
LD2416小尺寸实拍图
Download link for manual:
https://drive.google.com/drive/folders/16v5y2h3KQF5KoFMrhFrOOQA8IVLWs1hS
1. Introduction
HLK-LD2416 is a very small AIP human life presence sensor in the Hailingke 24G radar series, which includes extremely simplified 24GHz sensor hardware 2416 and human presence sensing intelligent algorithm firmware, capable of detecting sitting and lying human bodies.
The hardware HLK-LD2416 is equipped with an ICL111AAIP millimeter wave sensor, a high-performance 24GHz one transmitter one receiver antenna, and peripheral circuits, as well as an AIP chip
Line embedding, no need for high-frequency boards, faster processing. The human presence sensing algorithm adopts millimeter wave sensor distance measurement technology and S1 series chip proprietary technology. The advanced radar signal processing technology enables precise perception of motion, micro motion, and sitting still. The firmware of the intelligent algorithm for human presence sensing is mainly used in indoor scenes are used to perceive whether there is motion, micro movement, or the presence of human bodies in the area, and to refresh the detection results in real time.
The maximum sensing distance of HLK-LD2416 for a moving human body is 7.5m, and the sensing distance range, triggering and holding thresholds for different intervals can be easily configured. And no one reported the time. HLK-LD2416 supports GPIO and UART interfaces, plug and play, and can be flexibly applied to different intelligent scenarios and terminal production
Product. Simultaneously supporting automatic generation of detection thresholds, reducing manual debugging, improving detection accuracy, simplifying installation processes, and facilitating large-scale deployment.
1.1. Features
  • Intelligent design: equipped with a single-chip intelligent AiP millimeter wave sensor SoC, built-in antenna and intelligent algorithm
  • Extremely small size: sensor size 14mm × 14mm
  • Plug and play: Load default human body sensing configuration, plug and play
  • Frequency compliance: 24GHz ISM frequency band, can be certified by FCC, CE and domestic non commission spectrum regulations
  • Voltage support: 5V power supply
  • Low power consumption: average operating current of 80mA
  • Multi functional detection: effectively detects motion, micro movements, and stationary human bodies, and reports detection results in real time
  • Convenient processing: SoC has an integrated antenna, which is easy to design and has a shorter processing cycle
  • Visual configuration: Provides visualization tools to flexibly configure detection distance intervals and target disappearance delay times, and supports automatic generation of detection thresholds.
  • Sensing range management: supports sensing range division, effectively shields interference outside the range
  • No blind spot detection: can sense at a close distance of 0.2m
  • Large angle coverage: The detection angle reaches ± 60 °, covering a wide range of monitoring areas.
  • Diverse Installation: Supports various installation methods such as hanging on the top and wall
  • Independent configuration: triggering and maintaining states can be independently configured, with strong anti-interference ability
  • Enhanced environmental resistance: moisture resistance, corrosion resistance, anti-static, better environmental adaptability performance
1.2. Specifications
ParametersMinTypleMaxUnitRemark
Hardware specification of HLK-LD2416
Support frequency24-24.25GHzmeet the standards of SRRC,CE,FCC and No committee
Supports maximum sweep bandwidth-0.25-GHz
Maximum equivalent omnidirectional radiation power-9-dBm-
Power supply voltage4.755.3V-
Polarization modeDual polarization
Size-14*14-mm²-
Ambient temperature-40-85℃-
System performance
Detection range (wall mounted)-7.5-mMotion human body goals
-6-mMicro motion human target
-4-mResting human body target
Detection range (top mounted)-4.5-mMicro motion/motion human target
-3.5-mResting human body target
Detection accuracy-±0.15-mThe motion angle of the anti target within a straight-line distance of 6m from the sensor
Average working current-80-mA
Data refresh cycle-154-ms
1.3 PIN Description
PINNameFunctionDescription
Pin1RXUART_RX0~3.3V
Pin2VCCPower input5V
Pin3OUTUsed to report detection status: high level indicates presence, low level indicates absence0~3.3V
Pin4GNDGround0V
Pin5TXUART_TX0~3.3V
PIN DESCRIPTION 拷贝
