  4. 24G radar sensor module
  5. Hi-link 24G vehicle motobycle bitrycle ranging and speed measurement millimeter wave radar LD2451sensor module testing board
    $8.58
SKU-01-【LD2451单模块】 拷贝
24G radar module
HLK-LD2401:
https://drive.google.com/drive/folders/1lzr9p_PwXhF-kYRUyi09oY0CzpZk_lf3?usp=sharing
HLK-LD2402:
https://drive.google.com/file/d/1SmigbSjFt1toA7W5wEuI2Qy-1CSR6PQn/view?usp=sharing
HLK-LD2410D: https://drive.google.com/drive/folders/1inGVZojrH6ZmOwg66IucZ3wGe7JzQpX1?usp=sharing
HLK-LD2420: https://drive.google.com/drive/folders/1IggDH6ejNSOs8EklQbAXcqUI7KENSZLt?usp=sharing
HLK-LD2413:
HLK-LD2451: https://drive.google.com/drive/folders/1Xl7lnvCAQHD2xjOfU_lpxdr0GGXO0-F6?usp=sharing
HLK-LD6001:
https://drive.google.com/file/d/1lJ8Q1gavV_uBjRdbdkvXneLqPl5dG83O/view?usp=sharing
HLK-LD6001A:
https://drive.google.com/file/d/1FmuCOF4Ao6_-ismF7j4xBd8VGdTdG-GJ/view?usp=sharing
Product profile
HLK-LD2451 is a high sensitivity 24GHz mobile vehicle status sensing module developed by Hi-Link Electronics. Its working principle is to use FMCW FM continuous wave to detect the target within the detection range, combined with radar signal processing, accurate algorithm recognition, to realize high sensitivity vehicle status detection, which can identify the vehicles close or far away, and calculate the output of the target's speed, angle, distance and other auxiliary information.
This product is mainly used in outdoor scenes, sensing whether there is a vehicle close to or far away from the area, real-time output detection results, the longest sensing distance up to 100m. The longest sensing distance can be up to 100 m. Mobile software is provided to easily configure parameters such as sensing distance, speed, target direction and sensitivity to meet different application requirements. Support GPIO and UART output, plug and play, can be flexibly applied to different intelligent scenes and terminal products.
Product Characteristics
  • Plug and play, easy assembly method
  • Sensing distance up to 100m
  • Multi-level intelligent parameterization to meet the needs of scene changes
  • Mobile debugging and configuration tools
  • Configurable detection distance (10-100m freely adjustable)
  • Wide detection angle covering up to 3 lanes of traffic
  • 24GHz ISM band, FCC and CE spectrum regulation certifiable
  • The Ultimate Cost-Effective Choice
Application scenarios
 HLK-LD2451 vehicle sensing module can detect and recognize vehicles close to or far away from the vehicle, supports multi-level parameterization, and can be widely used in various intelligent products and terminal products, commonly used types are as follows
  • Highway intersection Installed at highway intersections, it senses the direction of vehicles traveling on the highway as close or far away, speed, distance, etc.
  • Non-motorized road
Detecting the blind spot in the rear field of vision, avoiding a car accident caused by a vehicle approaching from behind and changing lanes suddenly
  • Motorway Detecting distant vehicles behind, assisting the driver to determine the trajectory of the vehicle behind them
  • Smart Scene Sensing the approach of vehicles, automatic control of road gates, garage doors and other scenes automatically opened or closed
LD2451-PRODUCT DIAGRAM 拷贝
Module size size: 70mm x 35mm
Pin hole spacing: 2.54mm
PIN definition
pin numbernotationname(of a thing)functionnality
1VINPower input
Power supply input 5V
2GNDpower groundpower ground
3OT1GPIO1Indicator pin, 3 consecutive high and low outputs on first startup Outputs high level when a person is detected approaching
4TXSerial port TXserial tx pin
5RXSerial port RXserial rx pin
6OT2GPIO2temporarily unavailable
The App detection data information is showing below:
QQ_1723635031724
