  4. AC DC 50W
  5. AC/DC HLK50M12C/50M15C/50M24C 220V to 5V/9V/12V/15V/18V/20V/24V 50W Step Down Mini Power Supply Module Converter Power Module
    $5.85
产品型号-3 拷贝
  • Ultra small and the smallest volume in the industry in terms of homogeneity
  • Global universal input voltage (100~240Vac)
  • Low power consumption, green environmental protection, no-load loss<0.21W
  • Low ripple, low noise
  • Good output short circuit and overcurrent protection with self recovery capability
  • Input/output isolation withstand voltage 3000Vac
  • 100% full load aging and testing
  • High reliability, long-life design, continuous working time greater than 100000 hours 9
  • Meet UL, CCC, and CE requirements; Product design meets EMC and safety testing requirements
  • Adopting high-quality environmentally friendly waterproof thermal conductive adhesive for sealing, moisture-proof and vibration proof, meeting the IP65 standard for waterproof and dustproof
  • Economic solutions with high cost-effectiveness
  • Can work without external circuits
Technical standardUnitRemark
Working Temerature-25—+60 ℃
Storage temperature -40—+80 ℃
Relative humidity 5—95 %
Atmospheric pressure 80—106Kpa
Altitude≤2000m
Vibration coefficient 10~500Hz,2G10min./1cycle, 60min.each along X,Y,Z axes
Project nameTechnical requirementUnitRemark
Rated input voltage100-240Vac
Input vlotage range85-264VAC/120-350VDCVdc
The maximum input current≤1.5A
Input inrush current ≤60A
Input low start   ≤50mS
External fuse recommended3.15A/250Vac, Slow blow
Output Features(9V/5500mA)
No load rated output voltage9+0.3vdc
Full-load rated output voltage 9±0.3vdc
Short term maximum output current≥5500mA
Output current5500mA
Voltage regulation士0.2%
Load Regulation
士0.5
Input low voltage efficiencyVin=115Vac, Output full load>90%
Input high voltage efficiencyVin=230Vac,output full load>90%
Output ripple and noise
≤100
Rated input voltage, output at full load. Use a 20MHz bandwidth oscilloscope to test the load end with 47uF and 0.1uF capacitors.
mV
Output over-current protectionOutput 130-180% of maximum loadA
Short Circuit ProtectionShort circuit directly during normal output, and automatically resume normal operation after the short circuit is removed
Do not damage the entire machine
Output Features(12V/4200mA)
No load rated output voltage12+0.3vdc
Full-load rated output voltage 12±0.3vdc
Short term maximum output current≥4500mA
Output current4200mA
Load Regulation
士0.5
Input low voltage efficiencyVin=115Vac, Output full load>91%
Input high voltage efficiencyVin=230Vac,output full load>91%
≤100
mV
Output Features(15V/3500mA)
No load rated output voltage15+0.3vdc
Full-load rated output voltage 15±0.3vdc
Short term maximum output current≥3500mA
Output current3300mA
Load Regulation
士0.5
≤100
mV
Output Features(24V/2100mA)
No load rated output voltage24+0.3vdc
Full-load rated output voltage 18±0.4vdc
Short term maximum output current≥2200mA
Output current2100mA
Load Regulation
士0.5
≤100
mV
EMC
Multi Channel Application Circuit
Multi-EMC
