Hi-link HLK-ZW3021 capacitive touch fingerprint sensor module surface array semiconductor fingerprint recognition module
Visitor5632
Price$2.13
ZW0919: https://drive.google.com/drive/folders/11Hfr6bKT7IVFzgiRuf_XJhGJf0UnAFrK
ZW0906: https://drive.google.com/drive/folders/1Bf8uB-RA9bikIY9IvqDmcZD6dwdlEOwr
ZW0905: https://drive.google.com/drive/folders/1ZWkALY4HV5pF1nqXNWVdMYNIRgHB01zq
ZW0901: https://drive.google.com/drive/folders/1XtCFsMZ8JKsQx3yhjuWqhK7gvXFB9qMy
ZW0642: https://drive.google.com/drive/folders/1jXBPrjv7TLsIKRhWg4bhauMUmAHeT7RJ
ZW0623: https://drive.google.com/drive/folders/1ErDwzF-Hok0L3yVdE5GFwmbTEP8gphVJ
ZW0608: https://drive.google.com/drive/folders/1fUZlFCNMDEeryqCrYP1cqlvFcZ00cOCG
ZW111: https://drive.google.com/drive/folders/152YhI17TDGtX6wI1UvALbLdHL6ZlcsFw
ZW101: https://drive.google.com/drive/folders/1vSlF8b2zq1eI6UpXk3Jh3JKzu5nJ_RYs
ZW3021 is a capacitive fingerprint sensor MCU、 A multifunctional illuminated fingerprint module that integrates fingerprint algorithm. The MCU is embedded with its own dual-mode algorithm, with good FRR/FAR performance and fast recognition speed.
The fingerprint module is designed with low power consumption, small size, high static electricity level, fast response, and excellent image quality. It adopts a press type input scheme with fewer input times, and can be unlocked with just one press.
This module uses Command command communication for external communication and supports UART interface communication, making it convenient for users to integrate quickly.
Product features
Press type fingerprint recognition
Passive fingerprint detection
Output 8-bit 256 grayscale 3D image
360 ° fingerprint input and matching
The resolution is 508DPI
Ultra low power design( 6uA@7Hz )
ESD: Air voltage: 15KV/Contact voltage: 8KV
Parameters
Technical indicators
| Item | Parameter |
| Storage | 100 fingerprint data as standard |
| Sensor type | Capacitive touch sensor |
| Resolution | 508DPI |
| FRR. | <5% |
| FAR. | <0.001% |
| Fingerprint sensor shape | round |
| Image gray level | 256 level |
| Service life | one million times |
| Working temperature | -20℃~+75℃; |
| Storage temperature | -40℃~+85℃; |
Mechanical characteristics
| Project | Description | Unit |
| Module Dimension | 8.6*18.6 | mm |
| Resolution ratio | 108*108 | mm |
