  4. DC DC 10W
  5. VRB4805YMD-10WR3 VRB4812YMD/VRB4824YMD Power Isolation Module VRB4803/09/12/15/24DC-DC Voltage Reduction Power Module
    $4.15
VRB48xxYMD-10WR3-1
  • Ultra wide range input (2:1), 10W output
  • Conversion efficiency 91% (Typ)
  • Isolation voltage 1500Vdc
  • Standby power loss: 0.036W(Typ)
  • Ultra fast startup: 1ms(Typ)
  • Working temperature: -40°C ~ +85°C
  • Input undervoltage, output short circuit, overcurrent, overvoltage protection
  • Metal housing, low output ripple
Ripple & Noise50/80(max)
Mvp-p
ItemWorking conditions
Min.Typ.Max.Unit
Input voltage range(fully loaded/unloaded)12VDC Input Series3.3V -804/2826/4
others
-980/21004/4
24VDC Input Series3.3V -402/11004/4
others
-490/1413/2
48VDC Input Series3.3V -201/0.5207/1
others-87/0.3251/1
110VDC Input Series3.3V -78/390/0.5
others-100/0.3109/0.5
Reflected Ripple Current12VDC Input Series--60--mA
24VDC Input Series--40--
48VDC Input Series--30--
110VDC Input Series--20--
Impulse voltage  (Isec.max)12VDC Input Series-0.7--30VDC
24VDC Input Series-0.7--50
48VDC Input Series-0.7--100
110VDC Input Series-0.7--200
24VDC nominal input series, nominal input voltage--9
Input undervoltage protection12VDC nominal input series, nominal input voltage5.56.5
24VDC nominal input series, nominal input voltage5.56.5-
Start time
Nominal input voltage and constant resistance load-1-mS
PI type
CNT (Ctrl)*Module turned onCtrl dangling or TTL high level (3.5-12VDC)
Module turned offCtrl connect to GND or low level (0-1.2VDC)
Input current at shutdown-01mA
-±1.0%±2.0%-±2.0%±3.0%
±0.2%±0.5%-±1.5%±2.0%
Load adjustment rate
20%~100% rate
load, balanced
±0.5%
±1.0%-±4.0%±5.0%
