  4. 350W brick power module
  5. Hi-link DC DC 1/2 half brick power module HLK-350MH48S12 48V to 12V isolated and stabilized single circuit 350W
    $61.06
HLK-350MH48S12-1
36V input voltage,  full load output ----13A
----50mA
Input surge voltage (1sec. max.)Out-of-range input will cause permanent damage-0.7--100VDC
----36
----34
--±0.1±0.2
--±0.2±0.5
Ripple&Noise20MHz bandwidth, external capaciry ≥220μF--100120mVp-p
-10--+10%
125--150V
31.9--40.6A
--250--KHz
