  4. 300W brick power module
  5. Hi-link DC DC half brick power module HLK-300MH24S24A 24V to 24V isolated and stabilized single circuit 300W
    $71.50
HLK-300MH24S24A-1
10V input voltage,  full load output ----25A
----50mA
Input surge voltage (1sec. max.)Out-of-range input will cause permanent damage-0.7--60VDC
----10
----9.5
--±0.1±0.2
--±0.2±0.5
Ripple&Noise20MHz bandwidth, external capaciry ≥220μF--150240mVp-p
-10--+10%
125--140V
13.5--16.3A
Insulation resistanceInput-outputInsulation voltage 500VDC--100--MΩ
--300--KHz
