  4. 200W brick power module
  5. Hi-link DC DC 1/4 brick power module HLK-200MQ24S12A 24V to 12V isolated and stabilized single circuit 200W
    $52.50
9V input voltage,  full load output ----23A
----30mA
Input surge voltage (1sec. max.)Out-of-range input will cause permanent damage-0.7--50VDC
----9
----8.5
--±0.2±0.5
--±0.2±0.5
Ripple&Noise20MHz bandwidth, external capaciry ≥220μF--100120mVp-p
-20--+10%
125--140V
18.3--23.3A
Isolation VoltageInput-outputTest time 1 min, leakage current <3mA----2100
--210--KHz
