  4. 150W brick power module
  5. Hi-link DC DC 1/4 brick power module HLK-150MQ48S24A 48V to 24V isolated and stabilized single circuit 150W
    $44.70
HLK-150MQ48S24A-1
18V input voltage,  full load output ----8.5A
----10mA
Input surge voltage (1sec. max.)Out-of-range input will cause permanent damage-0.7--100VDC
----18
----16
--±0.1±0.2
--±0.2±0.5
Ripple&Noise20MHz bandwidth, external capaciry ≥220μF--80120mVp-p
-20--+10%
125--140V
6.8--8.8A
Isolation VoltageInput-outputTest time 1 min, leakage current <3mA----2100
--250--KHz
