  4. 150W brick power module
  5. Hi-link DC DC 1/4 brick power module HLK-150MQ24S28A 24V to 28V isolated and stabilized single circuit 150W
    $44.70
HLK-150MQ24S28A-1
9V input voltage,  full load output ----15A
----30mA
Input surge voltage (1sec. max.)Out-of-range input will cause permanent damage-0.7--50VDC
----10
----9
--±0.2±0.5
--±0.2±0.5
Ripple&Noise20MHz bandwidth, external capaciry ≥220μF--150190mVp-p
-20--+10%
125--140V
5.8--7.5A
--210--KHz
