  4. 150W brick power module
  5. Hi-link DC DC 1/4 brick power module HLK-150MQ24S19A 24V to 19V isolated and stabilized single circuit 150W
    $44.70
HLK-150MQ24S19A-1
9V input voltage,  full load output ----14A
----30mA
Input surge voltage (1sec. max.)Out-of-range input will cause permanent damage-0.7--50VDC
----10
----9
--±0.2±0.5
--±0.2±0.5
Ripple&Noise20MHz bandwidth, external capaciry ≥220μF--150190mVp-p
-20--+10%
125--140V
8.7--11A
Isolation VoltageInput-outputTest time 1 min, leakage current <3mA----2100
--210--KHz
