  4. 150W brick power module
  5. Hilink DCDC 1/4 brick power module 150MQ110S12A 110V to 12V isolated and stabilized single circuit 150W
    $43.16
HLK-150MQ110S12A-1
43V input voltage, Output 100W----3A
----10mA
Input surge voltage (1sec. max.)Out-of-range input will cause permanent damage-0.7--185VDC
----43
----42
--±0.1±0.2
--±0.2±0.5
Ripple&Noise20MHz bandwidth, external capaciry ≥220μF--80120mVp-p
-20--+10%
125--140V
13.5
--17A
--250--KHz
