  4. 200W brick power module
  5. Hi-link DC-DC 1/4 brick power module 200MQ540S24 540V to 24V isolated and stabilized single circuit 200W
    $78.26
HLK-200MQ540S24-1
350V input voltage, full load output----0.8A
----10mA
Input surge voltage (1sec. max.)Out-of-range input will cause permanent damage-0.7--800VDC
----340
----320
--±0.1±0.2
--±0.1±0.2
Ripple&Noise20MHz bandwidth, external capaciry ≥220μF--150240mVp-p
-10--+10%
125--140V
9.1
--11.6A
Isolation VoltageInput-outputTest time 1 min, leakage current <3mA----2500
--200--KHz
