  4. DC DC 10W
  5. 24V DC power module VRB2405/VRB240503/VRB240512/VRB2415/VRB2424S-10WR3 DC-DC isolated and regulated output
    $2.95
VRB12_S-10WR3-1
  • Ultra wide range input (2:1), output 10W
  • Conversion efficiency 88% (Typ)
  • Isolation voltage 1500Vdc
  • Ultra low standby power consumption: 0.036W (typical value)
  • Working temperature range: -40 ° C~+85 ° C
  • Input undervoltage, output short circuit, overcurrent protection
Item
Working conditionsMin.Typ.Max.Unit
Input current(full load/ no load)12VDC nominal input series, nominal input voltage3.3V-759/35815/50mA
5V
969/35992/12
other
969/9992/18
24VDC nominal input series, nominal input voltage3.3V-389/25398/45
5V
474/25485/45
other
474/9485/18
reflected ripple current 12VDC nominal input series, nominal input voltage-40-
24VDC nominal input series, nominal input voltage-30-
Impulse voltage (Isec. max)12VDC nominal input series, nominal input voltage
-0.7-25VDC
-0.7-50
Start voltage12VDC nominal input series, nominal input voltage
--9
--18
Input undervoltage protection12VDC nominal input series, nominal input voltage
5.56.5-
1215.5-
Start timeNominal input voltage and constant resistance load
-5-ms
PI type-
hot-swapping
Not support-
Contril (Ctrl)*module start
Ctrl floating or connected to TTL high level (3.5-12VDC)
module shutdown terminal
Ctrl connected to GND or low level (0-1.2VDC)
Input current when turned off
-610
Note: The voltage of the Ctrl control pin is relative to the input pin GND
ItemWorking and testing condition+V01-V02
Output loadload percentage0%-100%0%-100%
-±1.0%±2.0%-±2.0%±3.0%
±2.0%±0.5%-±1.5%±2.0%
Load adjustment rate
20%~100% rate
load, balanced
±0.5%
±1.0%-±4.0%±5.0%
Ripple & NoisePure resistive load, 20HMz bandwidth, peak-to-peak--80mVp-p150mVp-p-80mVp-p150mVp-p
Dynamic response step deviation25% nominal load step-±3.0%±5.0%-±3.0%±5.0%
Dynamic response recovery time-300us500us-300us500us
Output overcurrent protectionFull voltage range input110%lo150%lo200%lo
Output short circuit protectionFull voltage range inputSustainable, self-healing
Note: When tested under 0% -100% load conditions, the indicator of load adjustment rate is ± 5%; 20% -5% load ripple&noise less than or equal to 5% Vo. Ripple
The testing method for noise is the twisted pair testing method, which can add a capacitive load at the output end to reduce light load ripple.
