12V DC power module VRB1205/VRB1203/VRB1212/VRB1215/VRB1224S-10WR3 DC-DC isolated and regulated output
Visitor516
Price$2.95
Ultra wide range input (2:1), output 10W
Conversion efficiency 88% (Typ)
Isolation voltage 1500Vdc
Ultra low standby power consumption: 0.036W (typical value)
Working temperature range: -40 ° C~+85 ° C
Input undervoltage, output short circuit, overcurrent protection
| Input current(full load/ no load) | 12VDC nominal input series, nominal input voltage | 3.3V | - | 759/35 | 815/50 | mA |
| 5V | 969/35 | 992/12 | ||||
| other | 969/9 | 992/18 | ||||
| 24VDC nominal input series, nominal input voltage | 3.3V | - | 389/25 | 398/45 | ||
| 5V | 474/25 | 485/45 | ||||
| other | 474/9 | 485/18 | ||||
| reflected ripple current | 12VDC nominal input series, nominal input voltage | - | 40 | - | ||
| 24VDC nominal input series, nominal input voltage | - | 30 | - | |||
| Impulse voltage (Isec. max) | 12VDC nominal input series, nominal input voltage | -0.7 | - | 25 | VDC | |
| 24VDC nominal input series, nominal input voltage | -0.7 | - | 50 | |||
| Input undervoltage protection | 12VDC nominal input series, nominal input voltage | 5.5 | 6.5 | - | ||
| 24VDC nominal input series, nominal input voltage | 12 | 15.5 | - | |||
| Start time | Nominal input voltage and constant resistance load | - | 5 | - | ms | |
| Input filter type | PI type | - | ||||
| hot-swapping | Not support | - | ||||
| Contril (Ctrl)* | module start | Ctrl floating or connected to TTL high level (3.5-12VDC) | ||||
| module shutdown terminal | Ctrl connected to GND or low level (0-1.2VDC) | |||||
| Input current when turned off | - | 6 | 10 | |||
| Note: The voltage of the Ctrl control pin is relative to the input pin GND | ||||||
| Item | Working and testing condition | +V01 | -V02 | |||||
| Ripple & Noise | Pure resistive load, 20HMz bandwidth, peak-to-peak | -- | 80mVp-p | 150mVp-p | - | 80mVp-p | 150mVp-p | |
| Dynamic response step deviation | 25% nominal load step | - | ±3.0% | ±5.0% | - | ±3.0% | ±5.0% | |
| Dynamic response recovery time | - | 300us | 500us | - | 300us | 500us | ||
| Output overcurrent protection | Full voltage range input | 110%lo | 150%lo | 200%lo | ||||
| Output short circuit protection | Full voltage range input | Sustainable, self-healing | ||||||
Note: When tested under 0% -100% load conditions, the indicator of load adjustment rate is ± 5%; 20% -5% load ripple&noise less than or equal to 5% Vo. Ripple The testing method for noise is the twisted pair testing method, which can add a capacitive load at the output end to reduce light load ripple. | ||||||||
