DCDC isolated power module URB2405S-10WR3 URB2424S/03S/09S/12S/15S-10WR3 4:1 wide voltage input single output power converter module
Visitor513
Price$2.98
Ultra wide range input (4:1), output 10W
Conversion efficiency 88% (Typ)
Isolation voltage 1500Vdc
Ultra low standby power consumption: 0.036W (typical value)
Ultra fast start: 5mS (typical value)
Working temperature range: -40 ° C~+85 ° C
Input undervoltage, output short circuit, overcurrent protection
Metal casing, low output ripple
| Input current(full load/ no load) | 24VDC nominal input series, nominal input voltage | 3.3V | - | 429/5 | 440/12 | mA |
| 48VDC nominal input series, nominal input voltage | Other | - | 484/5 | 496/12 | ||
| reflected ripple current | 24VDC nominal input series, nominal input voltage | 3.3V | - | 190/4 | 215/8 | |
| 48VDC nominal input series, nominal input voltage | Other | - | 242/4 | 248/8 | ||
| Impulse voltage (Isec. max) | 24VDC nominal input series, nominal input voltage | -0.7 | 40 | - | ||
| 48VDC nominal input series, nominal input voltage | -0.7 | 30 | - | |||
| Start voltage | 24VDC nominal input series, nominal input voltage | - | - | 50 | VDC | |
| 48VDC nominal input series, nominal input voltage | - | - | 100 | |||
| Input undervoltage protection | 24VDC nominal input series, nominal input voltage | 5.5 | 6.5 | 9 | ||
| 48VDC nominal input series, nominal input voltage | 12 | 15.5 | 18 | |||
| Start time | Nominal input voltage and constant resistance load | - | 10 | - | ms | |
| Input filter type | PI type | - | ||||
| hot-swapping | Not support | - | ||||
| Contril (Ctrl)* | module start | Ctrl floating or connected to TTL high level (3.5-12VDC) | ||||
| module shutdown terminal | Ctrl connected to GND or low level (0-1.2VDC) | |||||
| Input current when turned off | - | 6 | 10 | |||
| Note: The voltage of the Ctrl control pin is relative to the input pin GND | ||||||
| Item | Working and testing condition | +V01 | -V02 | |||||
| Ripple & Noise | Pure resistive load, 20HMz bandwidth, peak-to-peak | -- | 80mVp-p | 120mVp-p | - | 80mVp-p | 120mVp-p | |
| Start delay time | 1mS | 1mS | ||||||
| Dynamic response step deviation | 25% nominal load step | - | ±3.0% | ±5.0% | - | |||
| Dynamic response recovery time | - | 300us | 500us | - | 300us | 500us | ||
| Output overcurrent protection | Full voltage range input | 110%lo | 150%lo | 200%lo | ||||
| Output short circuit protection | Full voltage range input | Sustainable, self-healing | ||||||
Note: When tested under 0% -100% load conditions, the indicator of load adjustment rate is ± 5%; 20% -5% load ripple&noise less than or equal to 5% Vo. Ripple The testing method for noise is the twisted pair testing method, which can add a capacitive load at the output end to reduce light load ripple. | ||||||||
