  4. DC DC 10W
  5. URF2405YMD-10WR3 URF2403/URF2409/URF2412/URF2415/URF2424YMD-10WR3 DCDC Isolation Power Module 24V to 3/9/12/15/24 DC/DC Power Converter Converter
    $3.25
URF_YMD-1
1. Wide input voltage range 4:1, isolated regulated output 10W
2. Isolation voltage 3000VDC
3. Transfer efficiency up to 88%
4. Quick Start:5mS(Typ)
8. Input undervoltage protection, output short circuit, overcurrent protection
General Features
ProjectOperating conditionsMin.Typ.Max.Unit
Insulation voltageInput-output, test time is 1 minute, leakage current is less than 1mA3000----VDC
Insulation resistance
Input-output,insulation voltage : 500VDC1000----MΩ
Isolation CapacitorInput-output,100KHz/0.1V--1000--pF
Operating temperatureReference temperature derating curve-40--+85℃
Storage temperature
-40--+125
Maximum temperature of the shell during operation
----+100
Storage humidityNo condensation5--95%RH
Pin soldering temperatureThe solder joint is 1.5mm away from the shell, 10 seconds----+300℃
Switching frequencyPWM mode--250--KHz
Viberation
10-55Hz,10G,30Min.alongX,YandZ
Shell material
Aluminum shell
Minimum time between failuresMIL-HDBK-217F@25℃--2X10^5-- Hrs
ItemWorking conditions
Min.Typ.Max.Unit
Input current (full load/ no load)24VDC Input Series3.3V -429/5440/12mA
others-502/5521/12
48VDC Input Series3.3V -190/4215/8
others
-251/4258/8
110VDC Input Series3.3V -87/190/2
others
-100/1109/2
Reflected ripple24VDC nominal input series, nominal input voltage--40--mA
48VDC Input Series--30--
110VDC Input Series--20--
Impulse voltage (Isec.max)24VDC Input Series-0.7--50VDC
48VDC Input Series-0.7--100
110VDC Input Series-0.7--200
Starting voltage24VDC nominal input series, nominal input voltage--9
110VDC nominal input series, nominal input voltage3236
Startup timeNominal input voltage and constant resistance load
-10-mS
PI type
Remote control terminal(Ctrl)*Module turned on
Ctrl floating or connected to TTL high level (3.5-12VDC)
Module turned off
Ctrl is connected to GND or low level (0-1.2VDC)
Input current at shutdown
-610mA
Note: *Ctrl control pin voltage is relative to input pin GND
Output loadload percentage0%-100%0%-100%
-±1.0%±2.0%-±2.0%±3.0%
±0.2%±0.5%-±1.5%±2.0%
Load adjustment rate
20%~100% rate
load, balanced
±0.5%
±1.0%-±4.0%±5.0%
Ripple & NoisePure resistive load, 20HMz bandwidth, peak-to-peak--50mVp-p120mVp-p-50mVp-p120mVp-p
Startup delay time
-5ms--5ms-
Dynamic response step deviation25% nominal load step-±3.0%±5.0%-±3.0%±5.0%
Dynamic response recovery time-300μs500μs-300μs500μs
Output overvoltage protectionFull voltage range input110%Vo-160%Vo
Output overcurrent protectionFull voltage range input110%Io150%Io200%Io
Output short circuit protectionFull voltage range inputSustainable, self-healing
① For product models with output voltages of ±5VDC and ±9VDC, under 0%-5% load conditions, the maximum output voltage accuracy is ±5%;
②When tested under the working conditions of 0%-5% load, the index of the load adjustment rate is ±5%;
③0%-5% load ripple & noise less than or equal to 5% Vo. Ripple and noise test method Twisted pair test method, you can add capacitive load at the output to reduce light load ripple.
