VRB2412ZP-6WR3 Power Converter VRB2405/VRB2415/VRB2424ZP-6WR3 DC-DC isolated stable voltage output power supply module
Visitor532
Price$3.48
Ultra wide range input (2:1), output 6W
Conversion efficiency 91% (Typ)
Isolation voltage 1500Vdc
Ultra low standby power consumption: 0.036W (typical value)
Ultra fast startup: lmS (typical value)
Working temperature range: -40 ° C~+85 ° C
Input undervoltage, output short circuit, overcurrent, overvoltage
Metal casing, low output ripple
International standard pins, PCB board direct insertion installation
| Input voltage range(fully loaded/unloaded) | 12VDC Input Series | 3.3V | - | 470/1 | 482/2 | mA |
| others | - | 588/1 | 602/2 | |||
| 24VDC Input Series | 3.3V | - | 235/1 | 241/2 | ||
| others | - | 294/1 | 301/2 | |||
| 48VDC Input Series | 3.3V | - | 118/0.5 | 121/1 | ||
| others | - | 147/0.5 | 151/1 | |||
| 110VDC Input Series | 3.3V | - | 51/0.3 | 53/0.5 | ||
| others | - | 64/0.3 | 66/0.5 | |||
| Reflected Ripple Current | 12VDC Input Series | -- | 60 | -- | mA | |
| 24VDC Input Series | -- | 40 | -- | |||
| Impulse voltage (Isec.max) | 12VDC Input Series | -0.7 | -- | 25 | VDC | |
| 110VDC nominal input series, nominal input voltage | - | - | 72 | |||
| Input undervoltage protection | 12VDC nominal input series, nominal input voltage | 5.5 | 6.5 | |||
| 24VDC nominal input series, nominal input voltage | 5.5 | 6.5 | - | |||
| 48VDC nominal input series, nominal input voltage | 13 | 18 | - | |||
| 110VDC nominal input series, nominal input voltage | 28 | 36 | - | |||
| Output voltage regulation | Input voltage range | - | No adjustment end | - | - | No adjustment end | - | |
Note: ① For product models with output voltages of ± 5VDC and ± 9VDC, the maximum output voltage accuracy is ± 5% under 0% -5% load conditions. ② When tested under 0% -00% load conditions, the load adjustment rate indicator is ± 5%; ③ 0% -5% load ripple&noise less than or equal to 5% Vo. The testing method for ripple and noise is the twisted pair testing method, which can reduce light load ripple by adding capacitive load at the output end. | ||||||||
