  4. DC DC 6W
  5. VRA2405ZP-6WR3 Power Converter VRA2403/09/12/15/24ZP-6WR3 DC-DC isolated stable voltage output power supply module
    $3.66
VRA_ZP-1
  • Ultra wide range input (2:1), output 6W
  • Conversion efficiency 91% (Typ)
  • Isolation voltage 1500Vdc
  • Ultra low standby power consumption: 0.036W (typical value)
  • Ultra fast startup: lmS (typical value)
  • Working temperature range: -40 ° C~+85 ° C
  • Input undervoltage, output short circuit, overcurrent, overvoltage
  • Metal casing, low output ripple
  • International standard pins, PCB board direct insertion installation
ItemWorking conditions
Min.Typ.Max.Unit
Input voltage range(fully loaded/unloaded)12VDC Input Series3.3V-470/1482/2mA
others-588/1602/2
24VDC Input Series3.3V-235/1241/2
others-294/1301/2
48VDC Input Series3.3V-118/0.5121/1
others-147/0.5151/1
110VDC Input Series3.3V-51/0.353/0.5
others-64/0.366/0.5
Reflected Ripple Current12VDC Input Series--60--mA
24VDC Input Series--40--
48VDC Input Series--30--
110VDC Input Series--20--
Impulse voltage  (Isec.max)12VDC Input Series-0.7--25VDC
24VDC Input Series-0.7--50
48VDC Input Series-0.7--100
110VDC Input Series-0.7--200
110VDC nominal input series, nominal input voltage--72
Input undervoltage protection12VDC nominal input series, nominal input voltage5.56.5
24VDC nominal input series, nominal input voltage5.56.5-
48VDC nominal input series, nominal input voltage1318-
110VDC nominal input series, nominal input voltage2836-
PI type
Output loadload percentage0%-100%0%-100%
-±1.0%±2.0%-±2.0%±3.0%
±0.2%±0.5%-±1.5%±2.0%
Load adjustment rate
20%~100% rate
load, balanced
±0.5%
±1.0%-±4.0%±5.0%
-No adjustment end--No adjustment end-
① For product models with output voltages of ± 5VDC and ± 9VDC, the maximum output voltage accuracy is ± 5% under 0% -5% load conditions.
② When tested under 0% -00% load conditions, the load adjustment rate indicator is ± 5%;
③ 0% -5% load ripple&noise less than or equal to 5% Vo.
The testing method for ripple and noise is the twisted pair testing method, which can reduce light load ripple by adding capacitive load at the output end.
