URA2405ZP-6WR3 Power Converter URA2403/09/12/15/24ZP-6WR3 DC-DC isolated stable voltage output power supply module
Visitor518
Price$3.90
Ultra wide range input (2:1), output 6W
Conversion efficiency 91% (Typ)
Isolation voltage 1500Vdc
Ultra low standby power consumption: 0.036W (typical value)
Ultra fast startup: lmS (typical value)
Working temperature range: -40 ° C~+85 ° C
Input undervoltage, output short circuit, overcurrent, overvoltage
Metal casing, low output ripple
International standard pins, PCB board direct insertion installation
| Input voltage range(fully loaded/unloaded) | 24VDC Input Series | 3.3V | - | 235/1 | 241/2 | mA |
| others | - | 294/1 | 301/2 | |||
| 48VDC Input Series | 3.3V | - | 118/0.5 | 121/1 | ||
| others | - | 147/0.5 | 151/1 | |||
| 110VDC Input Series | 3.3V | - | 51/0.3 | 53/0.5 | ||
| others | - | 64/0.3 | 66/0.5 | |||
| Reflected Ripple Current | 24VDC Input Series | -- | 40 | -- | mA | |
| Impulse voltage (Isec.max) | 24VDC Input Series | -0.7 | -- | 50 | VDC | |
| Output voltage regulation | Input voltage range | - | No adjustment end | - | - | No adjustment end | - | |
Note: ① For product models with output voltages of ± 5VDC and ± 9VDC, the maximum output voltage accuracy is ± 5% under 0% -5% load conditions. ② When tested under 0% -00% load conditions, the load adjustment rate indicator is ± 5%; ③ 0% -5% load ripple&noise less than or equal to 5% Vo. The testing method for ripple and noise is the twisted pair testing method, which can reduce light load ripple by adding capacitive load at the output end. | ||||||||
