  3. DC DC brick power module
  4. 300W half brick power module
  5. Hi-link DCDC Half Brick Power Module 24V to 24V Isolated and Stabilized Single Circuit 300W HLK-300MH24S24A
    $57.98
300MH24S24A product list-3 拷贝
300V input voltage, full load output----25A
----50mA
Input surge voltage (1sec. max.)Out-of-range input will cause permanent damage-0.7--60VDC
----10
Input under-voltage protectionNo-load test----9.5
--±0.1±0.2
--±0.2±0.5
Ripple&Noise20MHz bandwidth, external capaciry ≥220μF--150240mVp-p
-10--+10%
Over Temperature ProtectionMaximum surface temperature of product metal substrate105115125
125--140V
13.5
--16.3A
Insulation resistanceInput-outputInsulation voltage 500VDC--100--
--300--KHz
dimension 拷贝
