  4. DC DC 15W
  5. URB4805YMD-15WR3 URB4812YMD/ URB4815YMD/URB4824YMD DC-DC isolated dual output 48V to 5v/12v/15v/24v power converter module
    $6.99
产品型号URB_YMD-15WR3 拷贝
1. Ultra wide range input (4:1), output 15W
2. Conversion efficiency 91%(Typ)
4. Ultra low standby power consumption: 0.036W (typical)
5. Ultra fast start: 1mS (typical)
Storage temperture-40—+125 ℃℃
Vibrate10-55Hz,10G,30Min.alongx,YandZ
Input current
(full load/no load)
24VDC Input Series3.3V-625/30640/50mA
5V-694/30710/50
12V-694/69710/35
15V-687/69703/15
24V-687/10703/20
±5V-718/25735/35
±12V-686/1.5702/2
±15V-686/1.5702/2
±24V-686/1.5702/2
48VDC Input Series3.3V-313/15320/30
5V-348/15356/30
12V-344/3352/11
15V-344/3352/11
24V-344/4352/11
±5V-359/1368/1.5
±12V-343/1351/1.5
±15V-343/1351/1.5
±24V-343/1351/1.5
Reflection ripple currentRated input voltage-30-mA
Impulse voltage
(lsec.max)
24VDC Input Series
-0.7--50
48VDC Input Series
-0.7--100
Start Voltage24VDC Input Series
--9
48VDC Input Series
--18
Input undervoltage protection
24VDC Input Series
5.56.5-
48VDC Input Series
1215.5-
PI type
Project nameWorking and testing condition+Vo1-Vo2
Output load load percentage0%-100%0%-100%
-±1.0%±2.0%-±2.0%±3.0%
Linear adjustment rate
input voltage range-
±0.2%
±0.5%-±1.5%±2%
Load adjustment rate
20%-100% rated load, balanced load-±0.5%±1.0%-±4.0%±5.0%
Ripple & NoisePure resistive load,20MHz broadband, peak to peak, 5%-100% load
-50mVp-p80mVp-p-50mVp-p80mVp-p
Start time delay
-1ms--1ms-
Input vlotage adjustmentinput voltage range-no adjustment--no adjustment -
Dynamic response step deviation
25% nominal load step
-±3.0%±5.0%-±3.0%±5.0%
Dynamic response recovery time
-300μs500μs-300μs500μs
full voltage input range110%Vo-160%Vo
Output overcurrent protectionfull voltage input range110%lo150%lo200%lo
Output short circuit protectionfull voltage input range
sustainable, self-recovery
Component No.24V input48V input
FuseFollow up on customer needs and connect corresponding fuses
MOV1/Varistor14D560K14D101K
ldm1/Common mode inductance10mH15mH
CO,C1 Ceramic capacitors1uF/50V1uF/100V
E1,E2 Electrolytic capacitor100uF/50V100uF/100V
LDM2/Differential mode inductance1nF/250Vac
QQ_1727169617223
Component No.3.3V output±5V or 5V output
±9/±12V or 9V/1V
 output
±15 or 15V output±24 or 24V output
LDM3/Common mode inductance0.47uH1uH2.2uH2.2uH4.7uH
LDM4/Common mode inductance0.47uH1uH2.2uH2.2uH4.7uH
LDM5/Common mode inductance-1uH2.2uH2.2uH4.7uH
C2,C3 Electrolytic capacitor220uF220uF100uF100uF68uF
C5,C6 Electrolytic capacitor220uF220uF100uF100uF68uF
C4 Ceramic capacitors1uF/50V
dimension 拷贝
