AC to DC 40W HLK-40M09C/40M12C/40M15C/40M24C Step Down mini Power Supply Converter Module Insert EMC Electric Circuit
Visitor2628
Price$4.38
| Altitude | ≤2000 m |
| Input vlotage range | 85-305VAC/120-350VDC |
| The maximum input CURRENT | ≤0.4A |
| Input baund | 47-63Hz |
| Input low start | ≤50mS |
| External fuse recommended | 2A/250Vac, Slow blow |
Output Features(9V/4400mA)
| No-load rated output voltage | 9±0.2Vdc |
| Full-load rated output voltage | 9±0.2Vdc |
| Short term maximum output current | ≥6660mA |
| Rated output current | 4440mA |
Output short circuit protection | Short circuit directly during normal output, and automatically resume normal operation after the short circuit is removed |
Output Features(12V/3330mA)
| No-load rated output voltage | 12±0.1Vdc |
| Full-load rated output voltage | 12±0.1Vdc |
| Short term maximum output current | ≥5000mA |
| Rated output current | 3330mA |
Output Features(15V/2660mA)
| No-load rated output voltage | 15±0.1Vdc |
| Full-load rated output voltage | 15±0.1Vdc |
| Short term maximum output current | ≥3900mA |
| Rated output current | 2660mA |
| Voltage regulation rate | ±0.1% |
Output Features(18V/2220mA)
| No-load rated output voltage | 18±0.1Vdc |
| Full-load rated output voltage | 18±0.1Vdc |
| Short term maximum output current | ≥3330mA |
| Rated output current | 2220mA |
Output Features(24V/1660mA)
| No-load rated output voltage | 24±0.2Vdc |
| Full-load rated output voltage | 24±0.2Vdc |
| Short term maximum output current | ≥2500mA |
| Rated output current | 1660mA |
