AC to DC 10W 5V/9V/12V/15V/24V step down mini power switch supply power converter module HLK-10M05L/10M12L/10M15L/10M24L
Visitor2613
Price$1.75
For the specific model you need, please leave you message and we will contact you for conforming.Thank you inadvance.
| Altitude | ≤2000 m |
| Input low start | ≤300mS |
| No-load rated output voltage | 5.0±0.1Vdc |
| Output over-current protection Output maximum load | 110-150% A |
| Ripple/Noise | ≤100mVp-p(Typ:50) |
