  4. AC DC 40W
  5. ACDC 40W isolated power module HLK-40LC12/40LC09/40LC15/40LC18/40LC24 220V to 9V12V15V18V24V voltage regulator built-in EMC circuit wide voltage input
    $4.55
product list-3 拷贝
The 40WLC series module power supply is a small-sized, high-efficiency module power supply designed by Hailingke Electronics for customers. It has the advantages of a maximum input AC voltage of 305V, low temperature rise, low power consumption, high efficiency, high reliability, and high safety isolation. It has been widely used in industries such as smart homes, automation control, communication devices, and instrumentation.
  • Ultra thin, compact, and the smallest volume in the industry
  • Global universal input voltage (85~305Vac)
  • Low power consumption, green environmental protection, no-load loss<0.1W
  • Low ripple, low noise
  • Good output short circuit and overcurrent protection with self recovery capability
  • Input/output isolation withstand voltage 3000Vac
  • 100% full load aging and testing
  • High reliability, long-life design, continuous working time greater than 100000 hours
  • Meet UL and CE safety requirements;
  • Using high-quality environmentally friendly waterproof thermal conductive adhesive for sealing, moisture-proof and vibration proof, meeting the IP65 standard for waterproof and dustproof
  • Economic solutions with high cost-effectiveness
  • Can work without external circuitry
  • 1-year quality warranty period
Working Temerature-25—+60 ℃
Storage temperature-40—+80 ℃
Relative humidity5—95 %
Altitude≤2000 m
Rated input voltage100-240Vac
Input vlotage range85-305VAC/120-350VDC
The maximum input CURRENT≤0.4A
Input frequency≤47-63Hz
Input low start≤50mS
External fuse recommended2A/250Vac,  Slow blow
Output Features(9V/4440mA)
No-load rated output voltage9.0±0.2Vdc
Full-load rated output voltage9.0±0.2Vdc
Short term maximum output current≥6660mA
Rated output current4440mA
Voltage regulation rate±0.2%
Load regulation  rate±0.5%
Output over-current protection Output maximum load110-150% A
Ripple/Noise≤100mVp-p(Typ:50)
Output Features(12V/3330mA)
No-load rated output voltage12.0±0.1Vdc
Full-load rated output voltage12.0±0.1Vdc
Short term maximum output current≥5000mA
Rated output current3330mA
Output Features(15V/2660mA)
No-load rated output voltage15.0±0.31Vdc
Full-load rated output voltage15.0±0.1Vdc
Short term maximum output current≥3900mA
Rated output current2660mA
Voltage regulation rate±0.1%
Output Features(18V/2220mA)
No-load rated output voltage18.0±0.1Vdc
Full-load rated output voltage18.0±0.1Vdc
Short term maximum output current≥3330mA
Rated output current2220mA
Output Features(24V/1660mA)
No-load rated output voltage24.0±0.2Vdc
Full-load rated output voltage24.0±0.2Vdc
Short term maximum output current≥2500mA
Rated output current1660mA
Parameter RecommendationFunctionFunction
F1/FuseWhen the module is abnormal, protect the circuit from damage2A/250Vac, slow fuse
MOV1/VaristorProtect the module from damage during accumulated surges10D561K(The cumulative surge is to protect the module from damage)
C1/Safety capacitanceFiltering, security protection (EMC certification)0.1uF/275VAC(Filtering/safety protection/EMC certification)
L1/common mode inductorEMC certification)
Inductance: 10-30mH, testing requirements:
1KHZ/0.3V current: 300-700mA
  • Fuses and varistors are the basic protection circuits (must be connected).
  • If certification is required, safety capacitors and common mode inductors cannot be omitted. (This product comes with built-in EMI components, and there is no need to add X at the primary level Capacitors and common mode inductors. )
