AC-DC stabilized isolated power module 10LD05/10LD12/10LD24 compatible with 110/220/277V to 9V12V15V24V10W 305 full operating conditions
Visitor2805
Price$2.26
Global universal input voltage(85-305Vac)
Low power consumption, green enviroment protection, no-load loss<0.15W
| Working Temerature | -40—+85 ℃ |
| Altitude | ≤5000 m |
| Vibration coefficient | 10~500Hz,2G10min./1cycle, 60min.each along X,Y,Z axes. |
| Rated input voltage | 100-277Vac |
| Input vlotage range | 85-305VAC/100-430VDC |
| The maximum input CURRENT | ≤0.3A |
| Input inrush current | ≤30A |
| Input low start | ≤200mS |
| External fuse recommended | 2A/300Vac or 10Ω wire wound resistance, Slow blow |
Output Features (3.3V/2600mA)
| No-load rated output voltage | 3.3±0.2Vdc |
| Full-load rated output voltage | 3.3±0.2Vdc |
| Short term maximum output current | ≥2800mA |
| Rated output current | 2600mA |
| Voltage regulation rate | ±0.1% |
| Ripple/Noise | ≤120mV |
Output Features (5V/2000mA)
| No-load rated output voltage | 5.0±0.2Vdc |
| Short term maximum output current | ≥2200mA |
| Rated output current | 2000mA |
Output Features (9V/1100mA)
| No-load rated output voltage | 9.0±0.2Vdc |
| Full-load rated output voltage | 9.0±0.2Vdc |
| Short term maximum output current | ≥1300mA |
| Rated output current | 1100mA |
Output Features (12V/830mA)
| No-load rated output voltage | 12.0±0.2Vdc |
| Full-load rated output voltage | 12.0±0.2Vdc |
| Short term maximum output current | ≥1030mA |
| Rated output current | 830mA |
Output Features (15V/660mA)
| No-load rated output voltage | 15.0±0.2Vdc |
| Full-load rated output voltage | 15.0±0.2Vdc |
| Short term maximum output current | ≥810mA |
| Rated output current | 660mA |
Output Features (24V/410mA)
| No-load rated output voltage | 24.0±0.2Vdc |
| Full-load rated output voltage | 24.0±0.2Vdc |
| Rated output current | 410mA |
