UWB1205S-3WR3 UWB1212S/15S/03S/09S/24S-3WR3 DC to DC 12V to 3.3V/5V/9V//12V/15V/24V Isolation Power Converter Module
Visitor2783
Price$2.35
1. Wide input voltage range 8:1, isolated regulated output
3. Ultra small SIP package
7. International standard pin,direct installation of PCB board.
| Ripple & Noise | 50/100(max) | Mvp-p |
| Input current (full load/ no load) | 5VDC output Series | / | 314/13 | 857/30 | mA |
| other output Series | / | 320/15 | 328/30 | ||
Reflected ripple current | / | 50 | / | ||
| Impulse voltage(1sec.max.) | -0.7 | / | 50 | VDC | |
| Starting voltage | 5VDC nominal input series, nominal input voltage | - | - | 4.5 | |
| Linear adjustment rate | Full load, input voltage from low voltage to high voltage | -- | ±0.2 | ±0.5 | % | |
| Output Voltage Accuracy | 0%-100% load, input voltage range | -- | ±1.0 | ±3.0 | % | |
| No-load adjustment rate | 5%~100% no-load | -- | -- | ±1 | % | |
| Transient recovery time | 25% load step change | -- | 0.5 | 1 | ms | |
| Transient Response Bias | -- | ±5 | ±8 | % | ||
| Ripple & Noise | Pure resistive load, 20HMz bandwidth, peak-to-peak | -- | 50 | 100 | mVp-p | |
| Temperature Drift Coefficient | Full load | -- | ±0.02 | ±0.03 | %/℃ | |
Temperature Derating Curve
EMC Typical Application Circuits
| CY1 safety capacitor | 1nF/2KV | |
| D1 diode | RB160M-60V/1A | |
| R resistance | R=((Vc-Vd-1.0)/Ic)-300Ω | |
| Cd | 47nF/100V | |
