10LS03/10LS05/10LS09/10LS12/10LS15/10LS24 Hi-link AC-DC 220v to 3.3/5/9/12/15/24V 5w Step Down Mini Power Supply Converter Module
Visitor3722
Price$0.96
| Altitude | ≤2000 m |
| Input low start | ≤50mS |
Output Features(3.3V/2000mA)
| No-load rated output voltage | 3.3±0.2Vdc |
| Full-load rated output voltage | 3.3±0.2Vdc |
| Short term maximum output current | ≥2400mA |
| Rated output current | 2000mA |
Output Features(5V/2000mA)
| No-load rated output voltage | 5±0.1Vdc |
| Full-load rated output voltage | 5±0.1Vdc |
Output Features(12V/830mA)
| No-load rated output voltage | 12±0.3Vdc |
| Full-load rated output voltage | 12±0.3Vdc |
| Short term maximum output current | ≥1100mA |
| Rated output current | 830mA |
| Voltage regulation rate | ±0.3% |
Output Features(24V/420mA)
| No-load rated output voltage | 24±0.6Vdc |
| Full-load rated output voltage | 24±0.6Vdc |
| Short term maximum output current | ≥620mA |
| Rated output current | 420mA |
| Voltage regulation rate | ±0.6% |
