  4. DC DC 1W
  5. B0505S-1WR5 5V to 5V1W DC to DC 85% transfer efficiency power module/converter small SMD package
    $0.99
2. transfer efficiency 85%(Typ)
3. Isolation is required between input and output(isolation voltage 3000VDC)
4. output short-circuit protection .
5. operating temperature range :-40°C~+125°C
6. Small SMD package
7. Adopts high quality environmental protection, waterproof and heat conducting adhesive for filling and sealing, moisture-proof and vibration proof, meeting the waterproof and dustproof IP65 standard
Working enviroment temperature-40—+110℃
Storage temperture-40—+125 ℃℃
VIN(Vdc)FunctionRecommended value
Cout CapacitanceFilter capacitor2.2-10μA/50V
正反对比图 拷贝
