B1205S/B1203S/B1209S/B1212S/B1215S/B1214S-1WR3 12V to 3.3V/5V/12V/15V/24V 1W DC to DC power supply module converter
Visitor15522
Price$0.55
2. transfer efficiency 88%(Typ)
10. Adopts high quality environmental protection, waterproof and heat conducting adhesive for filling and sealing, moisture-proof and vibration proof, meeting the waterproof and dustproof IP65 standard
| Items | Working conditions | Unit | Notes |
| Related input voltage | 12 | Vdc | |
| Input voltage range | 10.8-13.2 | Vdc | |
| Maximum input current | ≤0.2 | A | |
| Reflection ripple current | 15 | mA | DC12V rated input voltage series |
| Impulse voltage | ≤18 | Vdc | |
| Starting voltage | 10.8 | Vdc | |
| Input under voltage protection | --- | Vdc | |
| Start delay time | --- | Vdc | Reted input voltage and constant resistance load |
| Input filter type | Capacitive filtering | ||
| Hot plug | Non-support | ||
Notes: test at room temperature
Output Characteristics(5V/200mA)
| Items | Technical parameters | Unit | Notes |
| No-load rated output voltageVdcVdc | 5V±15% | Vdc | |
| Short time maximum output current | ≥220 | mA | |
| Rated output current | 200 | mA | |
| Voltage regulation | ±1.5 | % | |
| Load regulation | ±12 | % | |
| Conversion efficiency | Vin=5Vdc, Output full load 88 | % | |
| Output ripple and noise(m Vp-p) | ≤100 Pure resistive load, 20MHz bandwith, peak to peak value | mV | |
| Output over-voltage protection | Output 110-160% of the maximum voltage | Vdc | |
| Insulation voltage | Input-output, test time 1 minute, leakage current less than 1mA/1500V | ||
| Insulation resistance | Input-output, insulation voltage 500VDC/1000MΩ | MΩ | |
| Isolated capacitor | Input-output,100KHz/0.1V 20pF |
1. Due to limited space, the above is only a list of typical products. If you need products outside the list, please contact our sales department.
2. The maximum capacitive load indicates the maximum capacitive load that + Vo or -Vo can connect to. If it exceeds this value, the product will not start normally.
| Cin Capacitance | Filter capacitor | 4.7μA/50V |
| Cout Capacitance | Filter capacitor | 2.2-10μA/50V |
| Lin inductance | Filter inductance | Inductance: 4.7uH |
| Lout inductance | Cin Capacitance | Inductance: 4.7uH |
